Honeywell HC-900-C50 I/O Network
jgooding
Jul 2018
SC
Long time lurker, first time poster. Does anyone know the protocol that the IO RJ45 Port talks on this processor?
I am trying to automate the rest of our equipment (other than temperature) and was wondering if I could connect anyone else's remote IO besides Honeywell's. I realize I can do this with the serial bus or the main ethernet port, I just do not want to put my IO on the plant network.
Regards,
Jon
The RS-485 port runs
- a proprietary LCN protocol to drive now-obsolete L&N/Honeywell HMI's; the protocol is not documented and of no practical use otherwise.
- Modbus RTU. There are two serial ports, one of which can be a Modbus Master, the other can be a concurrent slave.
Regards,
Jon
The I/O Port (IO Ethernet Port) is not only a proprietary protocol, it will not work properly if you put any other devices on that network. The IO network should be completely separate from any other network including other vendor's I/O network.
Hey Guys, I am getting random rack/slot errors. I go to download and everything is ok but then it has a error. For example - Yesterday everything...
369
Hello Guys, I'm working on Honeywell HC900. I am using the PID block. I have attached the Switch and loop block to it as well. I have attached a...
633
Does anyone have experience with setting up a HC900 to a prosoft card? Using this to communicate with an Allen Bradley plc
699
Hello Expert, I'm now with Honeywell Products. Can some one advise which connection setting to be used during HMI development using HCi Designer...
1,545
Greetings! I'm trying to connect HC900 to Kepserver in Plant via HC900 ethernet driver provided by Kepserver. I put the IP address and most of...
1,119
