Honeywell IPC 620
shaun croman
Oct 2003
carlisle
36
Does anyone know of a suitable OPC server for a honeywell IPC 620-35 which I can use to communicate with a scada package?
Any help -greatly appreciated
Check out this thread on Control.com:
http://www1.control.com/1026223377/index_html#1026223473
"If you are using the other processors (620-06, 10, 15, 25 or 35), there is a modbus module which can be added to the I/O rack. I believe that this will require the addition of coding to place the desired information in the module."
Once you're talking Modbus RTU, then any Modbus RTU OPC server (Kepware, Matrikon, Softing) should work.
Dan
IPC620 DDE Server
Pantek do a good server for the entire IPC 620 range, mostly for use with Intouch but good for any SCADA with DDE.
Its dongle protected and sells for a £995 (!) but I have a couple dongles in the draw somewhere from systems that we have taken out in the past.
mail me at [email protected] if your interested.
Matthew Anderson
Solved
Thanks for your help- Managed to solve it using Kepware- who have a user configurable driver for the 620 -9200 range
if you need any details I'll be happy to share
regards
IPC Honeywell IPC 620 Product
The Honeywell IPC 620 product line reflects the Honeywell continuing commitment to deliver proven logic control to specific markets that tie together in all segments of industrial control technology. Other members of this family are: 620-2590, 620-35, 620-3590, 620-25/35, 620-0080, 620-25/35, 620-0054, 620-0025.
Hi, I have problem with Honeywell IPC 620-15 PLC. It just stopped working and I can get it into RUN mode again, although keyswitch is in RUN mode...
1,765
I got two honeywell plc, IPC 620-15, the processor module is 620-1537. One is working, the other has lost its program. I need to copy the program...
8,121
Hi all, I need to convert IPC 620 Honeywell PLC Program to Control Logix. I don't have IPC 620 PLC programming manual to refer for some...
7,605
Hi, I have some questions on Honeywell CIM (communication Interface module, model 621-0043). We are using PCDM (PC Data Manager) to monitor our...
4,916
Hi I would like to know how to connect to plc honeywell ipc623-60 for make ladder diagram please advise me for hardware (how to make or to find...
6,469
