Horner HE-XC1E0 to MicroLogix ETH/IP
Jason Ozolins
Mar 2012
Fife Lake, MI
59
Has anybody set up a Horner HE-XC1E0 or similar model HMI to a MicroLogix? All the help and tutorials I have found only include Compact/Controllogix controllers via adding a generic ETH/IP card in RS5000 and importing back into cScape with the L5K file.
If anybody has dealt with these HMI's to RS500 controllers, I'd appreciate a nudge in the right direction.
Thanks,
Jason
It looks like the HMI supports both DF1 and the ODVA’s EtherNet/IP so at very least you could do it with DF1 and probably do it with EtherNet/IP.
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
95
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
96
I am having a problem communicating my PLC with Drive via Modbus connection. I start by opening the port and there is no problem, but then when I...
228
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
134
I seem to be making this harder than it should be, and Its not making any sense. I simply need to move a real variable to two integer variables...
1,001
