Horner PLC issue
unsaint33
Sep 2019
MInnesota
118
I am having an issue uploading program from my Horner PLC (EXL10e). The upload begins without a problem and I see the file transfer message and it seems to complete the uploading (in other words, no fault message of any kind). But the logic on my laptop is still NE (not equal) to the PLC logic. Any idea what is going on? I tried different USB cables and tried power cycling but did not fix the issue.
Another problem I am having with the same PLC is this... if I disconnect the USB cable while I am online with the PLC, the PLC locks up. I power cycle, then the PLC is good to go.
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
125
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
76
I am having a problem communicating my PLC with Drive via Modbus connection. I start by opening the port and there is no problem, but then when I...
213
I am using Cscape 9.9 service pack 8. I am writing my program as a variable based program not register based. When I try and have the output...
841
I have a Horner PLC that is reading Ascii string from a device. When the device responds, it responds with the hex value in Ascii. I need to...
2,385
