Horner PLC Networking
chall
Apr 2011
South Dakota
I'm trying to network two horner plc's together. I have both XE102's modded with the ethernet cards already. Using Cscape what are the steps I need to go through to connect the PLC's together so that the Fkeys on one will affect the programming in the other??
When I open the communication port should I use the TCP protocol or the Modbus RTU protocol to network my PLC's so that I can share %QG and %QI bits across the network?
-Cody
I'd suggest the ethernet, as it will be much faster. We've used the Horners to pass data and to allow programming all units from a single location, but not to have function keys directly pass through. I suspect you will have to have the function key in the master set a bit that is passed.
Have you contacted Horner? I've fiund their tech support to be pretty good.
I would suggest using the MJ1-MJ2 port and the build in Horner CAN set up.
Define "Global %x, where x is I,Q,AI,AQ and so on) on both PLC's.
Then define the Global points as a read or write for each PLC.
Minimum setup time, you get to use actual Horner registers (tags) and a proven comms network.
There's a section under the help menu that explains the usage and set up of "Global" variables, registers and such.
The Ethernet add-on (XEC I believe)is primarily used as a programming port.
The adders do not provide real ethernet functionality.
If you buy a unit with the build-in ethernet (such as an XE102e) then it's a different story.
The other option is to use the CsCAN port of each unit.
You network the 2 of them and exchange data.
Even less time consuming/painful setup.
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
91
I am having a problem communicating my PLC with Drive via Modbus connection. I start by opening the port and there is no problem, but then when I...
225
Hello, I’m new to this forum and if I’m posting incorrectly let me know. I’ve been having an issue I can’t seem to figure out. I’m sure it’s...
131
I am using Cscape 9.9 service pack 8. I am writing my program as a variable based program not register based. When I try and have the output...
846
I have a Horner PLC that is reading Ascii string from a device. When the device responds, it responds with the hex value in Ascii. I need to...
2,394
