horner XL4 PLC
urvinder_pal
Mar 2009
surrey
38
Hello Everyone,
I am new to Horner PLCs, I am trying to setup analog input and outputs but I am not sure how to assign the %AI and %AO to the terminal blocks, for example if i want to see a 0 to 10 volt signal from a potentiometer how can see the signal in the ladder logic.
what should be the settings like min and maximum and also does it have to be INT or DINT or real, how can i display this analog voltage thro an indicator on the screen setup.
Same is for analog output, where on the terminal block J2 shoul i wire analog in and analog out.
How should I/O configuration for channel 1, 2 ,3 and 4 should be set at ?
thanks for the help in advance.
Kanwar
Please refer to the datasheet that came with the PLC. This will show you the wiring diagram of the connectors that you are looking to program.
Here is a link to your model 6 PLC.
https://hornerautomation.com/wp-content/uploads/2018/10/MAN1148-01-EN-XL4_Model_6_Datasheet.pdf
Here is a reference to all of the manuals and datasheets for the controller:
https://hornerautomation.com/documentation-search/
The following manual will take you though the steps required to set up the analog input.
https://hornerautomation.com/wp-content/uploads/2014/12/MAN0964-02_XL4_User_Manual.pdf
15.7 Analog Input Configuration is the section that you want to read.
https://accautomation.ca/series/horner-xl4-series/
Regards,
Hi I'm new on Horner PLC XL4 OCS using Cscape software. After establishing ethernet comm I can upload/download program to/from the XL4 just fine...
1,221
So I'll preface by saying I'm familiar with the Horner XL4. I downloaded the BACnet IP and MS/TP protocols from Horner and I've been able to...
1,587
Greetings. I'm a total PLC neophyte so please bear with me. I'm still managing to wrap my head around concepts and the lingo. I've got a Horner...
2,496
Hi guys, My Horner XL4 is rebooting everytime it starts up with my code. I'm not sure what I did, but the SYSTEM button doesn't respond so I...
2,710
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
79
