Hotbackup Plc5/40 @ Controlnet
Fremen
Jan 2005
Santiago de Chile
Hello
Configuration situation:
Our control system have several type of plcs, (6) plc5/40, (4) slc500 5/04 and (4) controllogix, also (4) 1770-KFC15 and (1) engineering station.
There are two redundant plc5/40 over controlnet. These plcs have 1785-CHBM redundant system. We are using RSNetworx 4.11 and there, are defined status, diagnostic and configuration files. Also internal messages between both processors (1st - 2nd).
we have defined a diagnostic file (N20:0) in both processors (primary and secundary). In primary processor appear with length 88 (integers) but in the secondary the system define length 188 for the same register (¿?).
Both processors have the same application. When download program in secundary plc the controlnet change the lenght of this register??.
The problem with this situation is not possible to do correct crossload files then , when the primary pass to program or stop or fail situation, the secundary processor qualified ok and take the control, but happen disturb and open physical outputs.
Also , when we compare both rslogix applications show differences in processors details, like checksum, data files and memory usage.
Do you have some guideline or explanation for these situations??
Fremen
J
Hi, I am using PLC5/40C as Hot Backup in ControlNet.I used 1794 ACNR15/C ( Flex Module) as a controlNet adapter to connect I/Os.In RSNetworx for...
8,354
Joydip
J
Does Anyone know where I can find the download for the configuration tool listed in this technote...
2,743
I am working in the following system and i am having the problem mentioned below please help me and solution. System: Allen Bradly-PLC-5...
7,000
I am using the following formula and I am getting error, Invalid Expression - too many closing parenthesis. when i copy the formula to notepad or...
158
