how can I connect more than one Toshiba Ex100 together
zahaby
Apr 2003
does Toshiba EX100 Support ProfiBus protocol
and if not how can I connect them together
thansk very much
I am not sure which protocol the toshiba EX100 supports, I have never networked them.
But, I have an EX100 CPU module in my 'spares box' That has a network connection integrated within it. The Model No is PU12A. It has a station selector dial and terminals marked TXA, TXB, RXA, TRM, RXB,SG.
Hai Goody
May be you can help me
I am looking for PLC loader for winn or Dos
plc toshiba EX100
may be you kwon where can I donwload
Bgrds / Budi HS
Hello, friends, I am trying to upgrade a system that uses an Onrom incremental encoder (E6B2-CWZ6C) connected to a Danfoss VFD (FC360), but now...
276
Hello everybody, I'm using a Cp1l-EM40 PLC for my projects and this morning I changed the PLC IP from 192.168.250.2 to 169.254.67.1, because I...
3,261
A customer has a PLC5/40 that has a 1761-NET-ENI (series C) connected to the DF1 communication port. They have an old Panelview HMI connected on...
4,677
I have a SLC 5/03 connected to an Ethernet network via a Digi One IAP. The IAP is configured to allow the 5/03 to READ from a SLC 5/05 through the...
6,122
Hi every one I am using HMI from Beijer Electronics with OMRON PLC. Is it possible to connect more than one HMI with a single PLC?
8,174
