MarjoramMask
Hello everyone!
I have a unique problem that I am trying to solve. The load times between screens on my HMI are pretty standard, but 2 of the more complex displays are a bit slower to load and all of the elements display in their error state for a brief moment before it fully loads. I was wondering if there was a way to increase the loading speed between displays or have a loading window to cover everything up until it has finished loading all the elements. I have already removed all the HMI tags and replaced them with direct references to the PLC tags, as well as reduced the max tag update rate to the minimum for each display. I saw that with Site Edition you could pre-cache displays, but the option to do so is not available in the display settings, so maybe there's a solution there but I can't figure it out. I have a PanelView Plus 7 and I use FactoryTalk View Studio ME, release version 12.00.00 for the program, as well as an Allen Bradley 1769-L24ER-QB1B CompactLogix 5370 Controller.
Thanks in advance!
Thanks in advance!
