how can i tell if my ABB Robot is capable of welding
smcmanus
Jan 2006
Vancouver
109
I have an ABB IRB 4400. How can I tell if it is cable of welding? E.g. What cable connections on Controller and Robot should I look for? Appreciate your help.
The ABB IRB 4400 is a weld capable robot (I believe it is weld capable as standard, but it's been a little while since I played around with any ABB welders).
Without seeing the setup you have, I couldn't imagine what equipment you may or may not need to make it useable for any given application.
With a little more detail I may be able to at least point you in the right direction, however, I recommend you contact your local ABB rep who will be able to help you out a great deal more.
Edit: Correction and apologies - after talking to a colleague we came to the conclusion that this robot is more suited to Plasma Cutting than welding, but again I strongly suggest talking to ABB to be sure.
sir plz tell me how to interface servo motor with abb micrologoc 1400b plc plz give me detail of instruction and wht type driver may i use or tell...
2,528
Hi all, I need some local help to upload the Crimson program from a G310 Red Lion HMI. It cannot be easier than that. The thing is (for reasons...
1,071
Hello: Working on a program that needs to read some data from other Rockwell PLCs. Every second my program sends "CIP Data Table Read" command and...
30
7,035
I found these two software dongles in an old desk occupied by one of our automation guys. The black one looks like an Indusoft dongle but it...
3,782
Hello Everyone. I know with Rockwell stuff, the series card is important, cant' just swap a series A input card with a serB, even if the catalog...
1,919
