how could i add an extra sequence to a traffic light?
JerryRecords
Dec 2006
Chicago, IL.
i was working on a light sequencer or a four way intersection traffic light. I've designed my own light sequence using 2 SQO sequencers, and a TON. Pretty basic.
These are my light settings:
and these are the timer settings:
i had an idea of adding an extra rung like the ones above, with its own timer, the sequence is already set, and so its timer settings, for a 'NO' = 'Normally Open' crosswalk pushbutton. Basically, i want to add another sequencer that would run when the NO pushbutton is pressed. Would this automatically change the traffic lights so all would be red. and give me the walk signal.
This is how the simulation is given for my 'LogixPro' with the 'NO' Crosswalk Pushbutton at addresses: I:1/1 and I:1/0.
Any thoughts? I tried doin my own version but traffic lights just keep screwin up, like crazy.
How about inhibiting the SQO output when in WALK MODE.
Just let the crosswalk PB reset a timer that inhibits the SQO bits from going to the outputs and turns on all the red lights.
Also inhibit the TON T4:1 rung (which will stop the incrementing of the sequencer) too so that it picks up at the beginning of the step where it left off when the WALK timer expires...
You'd have to change you SQO destination to a memory word and then map it to the outputs through this logic. That "mapping", BTW is more common in real world SQO applications anyway.
hmm...how would i turn all red lights? would i write another sequencer to rapidly change the output to red lights?
which rung, the second? wouldnt that hold it by squeezin in a NO switch?
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
132
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
130
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,099
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
604
