FNC Member F Join Date May 2010 Location NJ Posts 84 Oct 25, 2011 #1 I am using string registers with a MicroLogix 1400 and need to clear some data. The CLR (clear) command does not work. How do I do this?
jac Member J Join Date Aug 2009 Location Ontario Posts 126 Oct 25, 2011 #2 I usually just have a NULL string labeled in the program and copy it into the string I want to clear. There may be a better way just never looked.
widelto Member Join Date Jul 2005 Location Barranquilla, Colombia Posts 3,392 Oct 25, 2011 #3 fill it with zeroes
Clay B. Lifetime Supporting Member C Join Date Jun 2005 Location Concord,NC Posts 1,304 Oct 26, 2011 #4 jac said: I usually just have a NULL string labeled in the program and copy it into the string I want to clear. There may be a better way just never looked. Click to expand... This is the method I have always used. I not sure how you would use the CLR instruction on a string. IF you want to clear your Read and Write buffer then you would use the ACL function.
