How do I connect to a SLC-5/02
fishenguy
Nov 2007
WESTERN PA
125
How can I connect to a SLC-5/02 that has a Panel View Plus 600 connected to it? I want to leave the PV connected and get on line to the CPU and maybe do some on-line editing. I need to know what cables and/or adapters if needed.
I'll be using my laptop USB port with a 9300-USBS.
Thanks and many Regards,
Dave
Hi Dave,
In short you can't... the 5/02 only has one port and if your PV is hooked to it you will need to remove the PV
You can set them up on a DH485 network using a AIC, but a simple connection is out unless the PV has a pass through and I don't think they do
edit: see here for the manual on a 1747-AIC it has the ways listed
http://literature.rockwellautomation.com/idc/groups/literature/documents/in/1747-in062_-mu-p.pdf
Also the 5/02 does NOT support on line edits. At least that is the way I recall it. It has been a LONG time since I worked on one.
Maybe someone else can confirm or deny this?
RSL
That is correct, RSL. No online editing for the SLC 500, 5/01, or 5/02. If that is the purpose, then it is doomed from the start. For online editing, it would be best to swap out the 5/02 to at least a 5/03.
Thank you guys for quick answers. I think you're right that the 5/02 doesn't support online editing. I was really hoping to watch what was going on and use the PV at the same time. I guess I'll try to get to it when production isn't running.
Thanks again, Dave
Hi All, I have a SLC 5/04 plc that I need to communicate to - however we don't have any null modem rs232 cables on site. I am very new to Allen...
2,644
Hi guys, Working on one of my client's systems with SLC processors, earlier today she called me and said she was having comms errors, had a solid...
2,050
I recently inherited some 5/04 CPUs and a single 5/02 CPU that I need to pull the programs from. The 5/04 CPUs didn't pose any problems. I...
3,059
Hello All, I’m trying to connect some SLC 5/03 and SLC 5/04 processors to RXLinx but am unable to see the connection to the processor in the...
2,320
Hey everyone! It has been a while since I have had an issue to post about but here I am back to gather some knowledge from yall. SLC5/05 talks to...
18
4,979
