How do I use a FB in Structured Text on Omron
theColonel26
Feb 2014
West Michigan
785
I've wrapped a Function Block around a OneShot/R_TRIG and I want to use it in structured text.
I have an Input bool called In and a Output called Out. My FB instance is called OneShot1.
However I am getting these errors
  • unexpected syntax for the '.'
  • Undefined identifier 'Out'
Code:
OneShot1(In:=Running);
If OneShot1.Out = true Then
END_IF;
The FB Logic
attachment.php
ST using the FB
attachment.php
https://echannel.omron247.com/marcom%5Cpdfcatal.nsf/PDFLookupByUniqueID/AE0D88A3A45ED8DE862575A700707901/$File/CX_programmer_V8.1_manual_en_200902.pdf?OpenElement
Check out the following SECTION 3 - Creating Function Blocks
You should have a variable table as well.
Hope this helps you out.
Regards,
Yes I have already declare an instance of FB OneShot as OneShot1.
It appear after deciphering this terrible documentation that you have to put an output variable in your call. You can't access the instances output varaible directly.
Way to follow standards omron.
Code:
OneShot1(In:= Running, Out=> OS_Out);
Is there a way in CX-Programmer to call Ladder Instructions from a structured text program? I can see several functions in the autocomplete...
1,974
Is there a way in CX-Programmer to call functions from a structured text program? I have found this manual that seems to describe the process...
1,062
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
187
I have an expression in a structured text routine of a Logix controller that looks more or less like the following: ResultInteger := Integer1 *...
389
Good evening. I display the step number of a SFC on a display. Sometimes, on a trip, it goes quickly through many steps and I need to prove to...
133
