How do you change data in a PLC?
aNewbie
Guest
A
Might be a dumb question, I know. But how do you change data in a PLC?
Just wondering really. Might get into the field.
I was just speaking in general. I don't have a specific application to spec, just thinking of getting into the field. Is data input directly or through software downloaded through a computer? How do you generally change data?
The "Learn PLCs" link at the top of the page is a good place to start when you have a general question such as this.
I would also recommend registering for the forum. It's fast, free and (relatively) painless :) Also, you will find that if (or when) you have more specific questions, the experts at this site will be more than willing to help you out...
Regards,
Rick
Hmmm?
Both ways, and many more... The other thing, there are many types of data, and apart many data types could have many different interfaces to the field devices... For example an analog signal could use a 4-20ma signal or 0-10vdc or many others... WOW, such a simple question but a very complex answer... Most PLCs use special input and output cards designed for the specified devices. Intern each device would be wired to a channel on the card (typical) however you can change data through communications to other PLCs, PCs, and many more things that I have never used....
Clear as mud?
How to change data in a PLC depends.
It depends on the controller you have.
It depends on the I/O you have and in essence what you are doing in your application.
It also depends if you are using an operator interface or not.
The structure of the program basically remains the same. What you are changing is variable information - timer and counter values.
With some controllers, this can be done on the fly through the programming software. With others, you would have to make changes, recompile and download your new program.
If you are using an operator interface, and it is set up by the OEM for you to access register information, then you would be able to change it that way.
A third way would be through an HMI software interface.
There are other devices that can interface to the PLC that will allow you to access the controller and change data, such as a modem.
Hope this helps.
God Bless,
The 'data' changes per the scan time. The actual programming used to 'make' it do what you want to do is 'programmed' into it.
Hmmmmmmmmmmm how do you change data in a PLC.
Well lets see.
Pushbuttons, selector switches, limit switches, thumbwheel switches, joysticks, analog devices, Timer/Counter access modules, Operator Interfaces, HMI software packages, Other PLC's, PLC programming software.
Did I miss anything?
Dave
How to do that can any one give me the how to write instructions example
839
I posted up some Python code on Github that will allow you to exchange data with CompactLogix and ControlLogix PLC's. It should run on anything...
19
16,481
Hey Guys, Our corporate standard for DB is MS SQL. I am looking for a hardware device that will manage bidirectional data exchanges between...
2,811
I need to add additional counters (C5) to the data table. I can add them offline. When I go online they do not appear. How do I get them online?
2,518
Hi Guys I am working with Step7 PLC and siemens Micromaster440 drives. Communication between drive and PLC has been established but I can not...
3,189
