PLC 5 Data Table change
John Marysz
Jul 2009
Indiana
I need to add additional counters (C5) to the data table. I can add them offline. When I go online they do not appear. How do I get them online?
You can do that, or leave it is REM (remote run) which will allow you to put the PLC in program or run mode from RSLogix5.
When you attempt to download to a running processor, the software will warn you that the PLC is in remote run mode and ask permission to switch it to program mode, and when done with the download, it will prompt you again to switch it back to run. Then you'll get another pop-up dialog box asking if you want to go online.
If the keyswitch is in RUN mode, you will not be allowed to download. Leaving the keyswitch in REM is the most convenient, but for greater security sometimes they are left in RUN mode.
Hope this helps,
Paul
Hi, every one, I Used Rslinx DDE/OPC function copied a data table value (N7: XX) and paste it as a link to a cell of Excel sheet. The pasted...
5,890
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
81
Hi Iam using monitouch hmi(V9 soft) with omron plc cj2m (CX programmer). In this I want to read a data from hmi to plc. The data was like...
103
I am working with beckhoff plc in twincat 3 environment. I have a array of struct which I want to make persistent. I declared it with...
113
Hi everyone id like to start by saying im not a PLC programmer so my technical terminology is limited. i would like advice on what software is...
299
