How do you interface a AB MPL servo motor to a AB Power Flex 700S drive
rdarling3599
Oct 2007
Alabaster, AL
How do you set up the PF 700S drive to commutate a MPL servo motor? THe PF700S manual describes how to enter the motor NPL data and the fact that you need their Hi Res optional encoder board installed so it can work with the MPL Stegmann encoder. However it does not seem to come out and describe how the drive commutates the servo motor so it will run.
Here is my (limited) knowledge on this subject: You have to set the drive up for PM (Permananet Magnet) motor during inital set-up. Depending on how new the 700S and HIM are, you may have to download updated firmware into the drive to give you all of the PM settings needed to set it up for use with the servo.
Hello world! The company I started working for has these valves that they ordered years ago as spares. now we have to add couple valves on...
201
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
865
Does anyone know why the connection interface is greyed out and says why I can only use Teleservice instead of the other options like PN/IE? I am...
232
I am attempting to generate a VBA script within FactoryTalk View SE to open a Google Chrome webpage (PI Vision) when an object is right-clicked...
127
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
222
