How does CLGX CMP real # to DINT
Might explain or complement the ability to manipulate real bits directly in earlier versions of 5k - they appear here to be forcing the sign bit to zero upon detecting the signed zero value.
Maybe the opposite?
  • 500 compares correctly i.e [EQU -0.0 0.0] evaluates to True
    • Even though the sign bit is 1 in the negative 0
      • See CPW of [F8:1 NEGATIVE_ZERO] to L9:2
  • Logix 5000 compares incorrectly i.e. [EQU -0.0 0.0] evaluates to False
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
112
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
420
So, I'm really just trying to get some experience by practicing with arrays. I'm using studio 5000 v33. I have one rung with an XIC bit that's...
238
