How I find Pump Running Hours
Have the run feedback from the pump starter or VFD run a timer. Every 60 seconds have the timer trip a counter for minutes and reset. Every 60 minutes have that counter trip another counter for hours and reset.
Or he could stand next to it with a stop watch and a clip board...
I was tempted to say "Look under the left front mounting foot, but decided to play it straight. Sometimes they lead with their chin, and it is no challenge!
LOL, I was thinking "Under the flower pot on the left side of the back door", same concept. :p
obi1987,
We do not know what you have, how you are running the pump, etc. etc., so it is going to be impossible to provide any meaningful help. We can ASSUME, given that this is a PLC forum, that you have a PLC involved. But if your PLC does not have a Real Time Clock or at least a time base pulse generator that can be run into a counter, then it cannot be used to track run time.
So IF it does have an RTC, and you have some sort of feedback signal from whatever is controlling your pump that tells you that the pump is running, you simply use that feedback signal to load an accumulated time value into a data register for the duration of each run period.
If you do not have a PLC, then go out and buy what is called an "Elapsed Time Meter" and connect it in parallel to the motor starter coil (ASSUMING you have a motor starter).
we have 4 pump and we should know working time of them each time we start the system , a pump with minimum1 time should start if we need much...
21
6,678
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
127
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
151
I have tested every screen and no single screen individually has this fault pop up, but when I compile and send to the PanelView it comes up. If I...
192
Hi, One of my customers has an old fabric tensile testing machine. The IC # AD7501KN of its controller has malfunctioned. This IC is related to...
89
