How programing S200 with Simatic SCL langugae
tayfur
Mar 2013
tr
Hello;
I am starting PLC prog. I know PC programing Delphi, pascal, Java, V.Basic. etc.
I want to programing S200 with SCL. (I dont know STL programing. SCl code easy for me :) )
İt is posibble?
Becasues I read SCL only for S300/400 series PLC.
thank ypu for feedback.
There is no SCL for S7-200.
Forget S7-200. It is now obsolete.
SCL is available for the S7-1200, which is the replacement for S7-200.
so, I want use cheap PLC. S71200 is high class.
I want to programing with only code. I dont want use Graph (STL) / Ladder diagram.
do you know diffrent PLC and Languages?
S7-1200 is the same price level as S7-200. S7-1200 is intended as the replacement for S7-200 so you will not have a jump in the price.
firstly;
Thank you for your intersting.
ok. You are true says. I check it list price. it is cheap.
Can I do make control with SCL for for S7-1200. how is it?
Because simatic says "for S7 -300 / 400 ".
how is make it? do it have special setting or update for S7-1200
sample code/ document /video????
firstly;
I have been using SCL with the S7-1200 for about a year. I know Simatic Step7 V11 works with it, as well as V12. I don't think V5.5 works though.
Try with Mitsubishi and GX IEC Developer. You have all capabilities even with cheapest PLC FX3S or FX1s, that cost around 180Eur...
Hello, I have Guard PLC 1600 by Rockwell Automation (it has been obsolete by them but still in the market and works fine). I need know if this...
1,224
I got DL06 AutomationDirect PLC to program with DirectSOFT6. It is a simple machine (40 in and 20 out, all digital), few valves, a simple conveyor...
23
6,908
Please suggest me programing cable for omron plc sysmac model no. Cpm2a
1,130
hi all, I am a PLC beginner.trying to learn how to program on my own at home. I am about to purchase a training kit online and just needed some...
17
5,193
please suguest me the cable names of following urgent 1) programming cable for PLC nexgenie 2000 model 2) PLC nexgenie 1000 model NG16DL
1,318
