RMA
Has anybody ever used the Beckhoff KL6001 serial interface terminal block? I need to use one (in conjunction with a BK3120 bus coupler) to access a new Cognex camera and the documentation I've got doesn't include a PLC sample program - come to that, it doesn't have any sort of sample program, just a somewhat terse description of all the registers.
If anybody's ever used one of these, I'd be eternally grateful for a snippet of sample code. Access is from a 315-2 DP via Profibus.
So far I haven't been able to definitely identify which version of the KL6001 I've been given (the documentation mentions 3-, 4-, 5-, and 6-Byte versions) but after loading the 4-Byte version in HW-Config and downloading it to the CPU, the BK3120 came up without any red LED's on, so it looks as though that much may be OK.
Thanks in advance (hopefully!)
Roy
Roy
