Beckhoff TwinCat 2.10 - PLC task access violation
Apr 2014
Vadodara
49
We are facing one issue in our TwinCat 2.10 system running on Beckhoff IPC C6140 with operating system Win2000
suddenly our machine got off or restart and Visual screen is showing following error..
TwinCAT PLC Server
'Plc Task Access violation (Page Fault)' P1:8 P2:807 a6a1b P3:7d10b4 P4:0
Can anyone help on this issue..
Thank You
Since nobody else answered, I'll give a shot. Google "page fault" in Windows. It refers to a problem reading virtual memory (hard drive used like RAM). Perhaps something like trying to open a file which you don't have rights to or the file is already open in another program (perhaps your own). See if your PLC code does any direct file I/O. Might also have to do with another program running in the background, such as System Manager or PLC-Control. Also check your virtual memory settings in Windows. Best to use actual RAM whenever possible since PLC must be real-time. Keep the graveyard shift from trying to run game programs on the IPC, or anything else which will tie up RAM. Check Beckhoff's recommendations on virtual memory settings. I would think "disabled" would be safest.
Hello, I was wondering if anyone know how to upload a PLC program to the Beckhoff TwinCAT 3 from a file? i.e. without having the development pc...
761
I still have a problem with two beckhoff PLC's . . . I connected one of them to a laptop . . The Beckhoff was running Windows CE, and I was able...
5,339
I started working with a KUKA robot that has an Beckhoff plc running in the background. Would need some help with the ST code there
3,172
I have made Twincat PLC Visu graphical interface. How can make a button which opens Windows XP Start menu? How to close Visu and shutdown PC so...
5,923
Currently we have many AB L30s in the field with no network monitoring capability. In a new project we will be installing BC9000s in many of the...
5,328
