How to Access remotely on S7-1200
Hossamhegab
Sep 2019
Cairo
23
Hi all,
I need to Access remotely on S7-1200 Station as the project will be carried out outside the countries and it will not be easy to troubleshooting the plc on site.
Note that the station is commented to HMI.
Any help will be appreciated
There are many solutions for your task, but you did not give any input except it is S7-1200. If you do not have enough networking knowledge, just buy one e w o n flexy with 4G sim card support or similar products (there are also other good products, but I use this) . Than you set it up at your office, mount it in enclosure box, connect it to the PLC and ship it to your customer. Price is acceptable - about 500$.
The device that provides the VPN connection (a PC or an internet Router such as the e w o n) must have an IP address on the machine side in the same subnet that the devices are using, and this IP address must be setup as the gateway/router in all the devices that you want to reach.
Whenever you make any program changes remotely, coordinate it in advance with the customer !
Hi, Does anybody have a practical solution for accessing the webserver in an S7-1200 remotely? My S7 is located on a piece of heavy lifting...
3,312
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
399
Dear Experts, I have just finished commissioning my first project in S7-300 (CPU315-2 DP) and so far the palletizer is running good. and now...
7,780
Hello ! I used to have a wireless access point that I could plug into a PLC network and set it with an IP address that fit onto my networks...
110
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
224
