How to Access Windows from SCADA PC hosting RSView32 with DeskLock
Jul 2007
Kiruna
600
Hi all,
I'm on site to migrate an RSView32 application into RSView SE application. I cannot shut down the RSVIew32 application due to logging of data etc.
I was hoping I could access Windows to grab the RSV directory but the DeskLock utility is configured to lock Windows out.
The "Exit Desklock" button is greyed out. There is 3 other options 1. Application Name 2. Restart Windows 3. Setup Desklock
Am I correct in saying that even if I get a shutdown if I use the Restart Windows options I'll still be locked out and the application will just relaunch upon boot up.
Any suggestions on how to access windows for a couple of minutes?
Do they have an administrator account for the PC? You could try using another PC on the network and going in through the hidden admin shares if they are still enabled.
ie. \\<computer name>\c$ for C: Drive, \\<computer name>\d$ for D: drive, etc.
If you reboot and use : (not sure of english expression) mode without echec
While booting on some pc you type CTRL+F8 or other specific key sequence and you can enter this mode that disable most of the autostart software...The key sequence needed is generally shown upon pc booting but you have to be fast to see it...
Morphius: If you can go into 'Setup Desklock' you are able to select windows mode (After a restart). Be aware that a password may be set on the desklock
So I just had a update on Windows 10 on two separate PC's and both are failing on RSWho anyone else having the issue? Both are the same issue...
3,058
Hi, An MP277 panel that logs data in CSV format, that's what I have now. I did my best to achieve trustable data, now I want to do something...
1,656
Hello. I am setting up an excel spreadsheet to monitor some data from a slc 5/04. I have dh+ wired back to a desktop pc with the pktxd card. The...
6,081
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
186
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
93
