RSLinx ~ Windows update ~ Access harmony.rsh
geniusintraining
Jun 2005
SC
8,276
So I just had a update on Windows 10 on two separate PC's and both are failing on RSWho anyone else having the issue?
Both are the same issue below, anyone know a fix?
update or version upgrade?
look in your c folder and see if you can find a folder called windows.old
if you do, you had a version upgrade and it did not install correctly.
I got my update or should I say version upgrade Monday.
Nothing worked in Explorer, Edge, or chrome.
I had to do a version recovery and now everything is fine with the world.
if it was an update, I would uninstall the update.
as further protection, I also create restore points before the updates.
regards,
james
So incase anyone else having these issues.... I had another update install yesterday that did the same thing, so now the two updates below have stopped RSLinx from opening RSWho for me
KB4054517
KB4056892
I recently changed to a new laptop and still have access to the old files. Does anybody know the location of the file that stores the configured...
1,172
Recently, I tried connecting to an Allen Bradley Compactlogix PLC (trying both USB and ethernet using a USB to Ethernet converter) that I am...
1,389
Can RSlinx be installed on Windows 10 home? If so does anyone have the procedure do this? Does a person need to install it using compatible mode...
4,576
Hi, I would like to know if any of you tried RSLinx Classic with a 64-bit operating system. We currently have a computer with RSLinx Classic but...
2,224
I have followed instructions for installing RsLinx RsLogix Emulate 500 RsLogix Micro English I have added the driver "EMU500 SLC 500 (DH485)"...
8,822
