RSLinx Classic Configured Drivers Windows Storage Location
AMarks95
Jul 2018
South Dakota
224
I recently changed to a new laptop and still have access to the old files. Does anybody know the location of the file that stores the configured drivers so I can copy/paste it into the same location on my new machine? Win10.
Go to your old machine and run the RSLinx Backup and Restore tool. It will allow you to Backup your current drivers to a file that you can copy to your new laptop. Then run the same utility on the new machine to Restore the drivers.
OG
From what I see, it is stored in the Windows registry:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Rockwell Software\RSLinx\Drivers
I don't see them stored as files. Thus the reason for the tool. But maybe someone else has an idea.
OG
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
192
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
161
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,591
Hello, I entered my controller IP address as 192.168.1.100 (Local) for 1769-L33ER. It worked fine until couple month and found the controller kept...
1,136
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,417
