RSLinx Classic Functionality
QasimFSH
Apr 2018
Adelaide
142
Hey All,
I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose communication with the network and devices?
Or what will happen?
The PLC's will keep on talking to one another, and any HMI devices, and any other automation hardware they're connected to.
What's going to happen is that whatever PC software on your workstation that is using RSLinx won't be able to use it anymore if you force it to shut down.
So RSLogix would time out and go offline, or RSView would stop displaying live data, or even FactoryTalk Transaction Manager might stop storing historical data into SQL.
But shutting down RSLinx doesn't interrupt the PLC networks or operation.
That warning appears if RSLinx is being closed and any RSLogix editor is opened (even if offline), or any other software on the machine is using it for data. If you are running a DDE/OPC connection using RSLinx then that connection will be interrupted. If it is just an editor that you are not using online with a PLC, then it should be fine to hit Yes, and close it.
If RSLinx Classic is your OPC Server, then of course it will stop working when you close it.
If you are using a different OPC Server, like Kepware or Matrikon, then it will be unaffected. The essence of those OPC Servers is that they have their own drivers and do not rely on RSLinx.
I think that there is also a way to run the RSLinx Service in your computer so that the application GUI is hidden, and any application using RSLinx still continue to perform.
I would recommend using RSLinx in this manner if you have any applications(RA or Non Rockwell) that utilize the RSLinxOPC server.
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
192
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,591
Hello, I entered my controller IP address as 192.168.1.100 (Local) for 1769-L33ER. It worked fine until couple month and found the controller kept...
1,136
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,417
Inexperienced user here. We are upgrading servers and currently have RSLinx Classic Lite with a dozen SLC505s on it. The new server will run FT...
812
