RSLinx Classic Question
tchiem
Jul 2021
Winnipeg
Hello, I entered my controller IP address as 192.168.1.100 (Local) for 1769-L33ER. It worked fine until couple month and found the controller kept disconnecting. Changed to different IP and later found this in RSLinx Classic tree: 192.168.1.101 [0.0.0.0], 1769-L33ER LOGIX5333ER. What does [0.0.0.0] mean in this situation? Thank you
I've seen the address in square brackets refer to a device's "actual" IP address when it is behind a Network Address Translation (NAT) device that RS-Linx is configured to browse with the ETH driver.
Hello every one. I have a computer to set up with RSlinx classic and rslogix5. First question is can I use my computer with RSlinx and RSlogix5 as...
23
6,900
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
191
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
158
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,590
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,416
