How to activate active X in wincc flex
google08
Jun 2011
Kiruna
51
It says in the error message that the control is not installed.
Did the project come from another PC where the it was originally programmed ?
Did it ever work before ?
The project came from other computer, I was trying to run the
scripts but I couldn't. I just wonder if it have some thing to do
with the active x component. I Tried to register it but I don't
know where to find that ocx
You need to have that OCX on both your own computer as well as the target computer(s).
I dont like the idea of an OCX that somehow makes a time-delay. I cant see how it works. And if it is linked to a script, and the OCX needs to finish for the script to finish, it will block all other scripts.
Good Morning , I'm merging another RS Logix 5000 PLC program ( CompactLogix ) into another . Everything is working great except this one...
3,726
Hi, i don´t get why my coil doesn't activate when the contact it´s true. I'm new to PLC programming, this is my first project. I'm attaching...
1,508
Hello Friends; I re-host the activation some days before successfully. Now i installed the software to another computer when we start Factory...
1,332
https://i.imgur.com/DxEkaxK.png (HMI IP is set at the device itself) This is my setup, i have a 315 CPU that controls 17 devices in total. In my...
1,812
Hello everyone. I am currently working on a project using a Panelview Plus 1500. A large amount of the inputs for the project are controlled with...
3,640
