How to change color of Text in Step 7
In Ladder editor go to Options --> Customize (or press Ctrl + Alt + E).
Then under the tab called view you can change the color of the text.
Maybe if you'd show exactly what you want, you'd get a decent reply.
I've looked at both pictures, read both posts and still do not know what you want.
Jeebs, the pictures show exactly what google08 wants....
First pic - what he wants
Second pic - what he gets
Open block, hit CTRL+Q a few times, decide which way you'd like it.
Also, in stead of giving your timer the symbolic name of "TIMEREXTRA 4 MOTOR 3", give it the following symbolic name: T300 and put the "TIMEREXTRA 4 MOTOR 3" in the comments section.
Then hit CTRL+Q a few times.
Note: View > Display with > Symbolic representation = CTRL+Q
Does anyone know how to change the text color of a TextBox control in Wonderware? I can change the background color of the TextBox, the text size...
5,609
Hi to every body, i'm newbe to FTV Studio; i need to know (and if is possibile how) change the color of a goto display button object. For...
5,043
Hello- I have a project where I have 3 buttons that write a value to a register (off/man/auto equals 0/1/2). I want the current mode to highlight...
1,727
Working with Factory Talk View ME with Plant PAX objects. I would like to be able to change the color of objects dynamically. I have loaded the...
4,068
New to the programming of a G310. I have a set of pipes I'd like to make change from green to red depending on a plc tag is high or low. I plan to...
1,703
