Red Lion Programming color change
a062549
Feb 2012
Home
139
New to the programming of a G310. I have a set of pipes I'd like to make change from green to red depending on a plc tag is high or low. I plan to reference which of the two valves is open to make my pipe show an active state.
Have looked for a how-to with no success, though the "Reference Manual" is very detailed, I'm needing the how they do that? method.
Thanks!
1.Under Core Primitives select Animated Image. Drag it into you screen.
2. Double click the primitive and select the number of images. Usually 2.
3.Then go to Symbols and select Pipes.
4.Select the pipe section you want to use and double click on it. You will get many different colors for the pipe section.
5.Click and drag the color pipe you want for Image 0 and for Image 1.
6. In the Image Select box you can select a Tag or a expression that will control what color is displayed and when.
This is one of those "when you do it once it will make sense".
Hi, I have a Red Lion E3 io counting output from weld cells, connected to a PTV station for the visuals. Our number of weld cells is set to...
1,563
Any thoughts on how I could get rid of all the individual pages and just have one page that shows all tools that are going to expire as well as...
1,547
Can anyone see what is wrong with this program? every time it gets to the Cell2 page it doesn't scroll any further. The goal is to have it switch...
1,468
I am pretty new to Red Lion and Crimson and I am trying to figure out a way that I can change the screen and Display a message based on the Inputs...
1,438
I am working on learning more about programming, and am having to try and teach what i know to new hires in our maintenance department. In order...
5,799
