Red Lion ProduTVity Programming
tespoors
Feb 2016
Ohio
I am pretty new to Red Lion and Crimson and I am trying to figure out a way that I can change the screen and Display a message based on the Inputs that are on. The inputs are connected to A CSDIO14 Module. I am trying to represent different tools based on the state of the inputs or a combination of the 4 inputs. I am assumeing I will have to write a program in the programs section but really don't know where to start.
I can't really test it without hardware, but here's an example to get you started.
I created a tag that takes the first four inputs from Module1 and converts them to a number from binary (0 through 15 for first four inputs). Since the module inputs are boolean, I am not 100% sure the complex code in my tag data source will work as-is. That conversion may not match your needs, but can be modified easily enough.
On that tag, I added a trigger to run a program (with 2000ms delay).
The program uses the switch/case functions (not well documented in the help files...) to GotoPage for up to 16 pages. All I put on the pages is a bit of text with the page number.
So try this out, pick it apart and welcome to the forum!
Paul
It may work but for some reason I am getting stuck on page 2 and not cycling back to main even when no inputs are on. here is my file.
While they came up quickly with a fix for the alarm date issue quickly I will have to drive around for a week or so, burning up a lot of fuel...
267
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
279
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
107
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
221
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
112
