How to change Profibus DP node number of Simocode DP?
bekrab
Mar 2011
Thailand
17
Simocode DP is ship with node number 126.
That node number is over node number of profibus DP (Max = 125).
How can we change default node number of Simocode DP?
Is there anyone know the solution?
We try with Win Simocode DP Smart/Professional but not success.
Thank in advance.
You have to use the SIMOCODE ES software
Step Description
1 Plug the PC cable into the system interface.
2 Start SIMOCODE ES software.
3 Open the menu Switchgear > Open Online.
4 Select RS232 and the corresponding COM interface. Press OK to confirm.
5 Open the dialog Device Parameters > Bus Parameters.
6 Select the DP address.
7 Save the data in the Basic Unit with Target System > Load to Switchgear. The address is set.
Read more in this manual page 394. đź“š
http://support.automation.siemens.com/DK/view/da/21362445
Hi, I wanted to establish a profibus communication between 2 plcs. One is S7 400 and other is S7 300 plc. Please let me know what is the right...
5,944
Hi all, I have a question, I want to change the address of a Profibus slave. My CPU315 is connect via ethernet. Is this possible over...
3,304
Hy Sirs, how can we change the profibus baudrate of a Simodrive from 12 mbits/s to 1.5 mbits/s ? does it automatically detect the baudrate ? or do...
2,706
two CPU under Profibus DP Master/Slave communication. do they exchange DB data? eg CPU1 DB1 -> CPU2 DB10 CPU1 DB2<- CPU2 DB11 is it...
4,839
hi guys I`ve got a profibus connection between a s7 315-2DP station and a s5-95u L2-DP. the connection is ok. I need to exchange data...
2,800
