Siemens -Profibus DP master/slave data exchange
tutu
Apr 2008
Toronto
30
two CPU under Profibus DP Master/Slave communication. do they exchange DB data?
eg CPU1 DB1 -> CPU2 DB10
CPU1 DB2<- CPU2 DB11
is it possiable? if so How I fill the address in DP-Slave Configuration Row?
Between master and slave is normally exchanged only i/o data.
Input words in the master are output words in the slave and vice-versa.
However, there is a method to use the cyclically exchanged i/o data to exchange a variable amount of data on event:
http://support.automation.siemens.com/WW/view/en/20987910
Between S7-300 stations max 100 bytes can be exchanged, of these max 8 bytes consistently.
Dose anyone have experience with Beckhoff FC3121 profibus master PCIe card connected to Siemens CP342-5 as a profibus slave? The data retrieved...
17
4,848
My tutor asked me for this small project: using S7-200 control MM440 with PROFIBUS. Because S7-200 with PROFIBUS module EM277 can only be PROFIBUS...
2,985
Hello Guys, I have s7-315-2 PN/DP with integrated DP. I have no CP module. PLC should be DP master. ON other side there is basler device DECS250...
3,503
For one of the projects, Customer has Profibus Network as below, Profibus Master 1 - PRM Module (Schneider) addressed (1) Profibs Master 2 -...
3,344
I have what appears to be a somewhat unusual configuration. I have a Compact Logix, with a ProSoft Profibus DPV1 master card, which is connected...
6,367
