How to change Profinet Interface?
Timer
Aug 2017
Germany
26
Hello, people. Me again. The same project, another problem. The PLC article # is 6ES7 512-1SK01-0AB0. There is only one in the Hardware Catalogue, I add it, download the HW and got an error for the port X1P1R. I checked Profinet Interface, it has article # 6ES7 193-6AR00-0AA0 by default for this port. But in fact the module connected to the PLC has # 6ES7193-6AP20-0AA0 on the faceplate and the port X1P1R is not an Eternet but looks like optical or someting like this. So question is - how can I change default profinet interface for this PLC?
Thanks for advance :)
You change the Bus Adapter (BA) in the device settings. The easiest way is to right click on the 2 ports in the picture, choose "change device" and then choose the correct bus adapter from the catalog.
Alternately, you can drag from the catalog onto on top of the ports. The cursor will change from a NO symbol to a Swap symbol of a red arrow circled around with a black arrow.
Thank you, and I'm sorry for such trivial question.
No need to be sorry. The wound you'd get from banging your head against the wall trying to figure it out sure wouldn't be trivial.
If you weren't expecting it, you'd never figure out that the one little section of picture was special....
Hello. I cannot change the SendClock settings for a PROFINET IO device. I need to slow down the CODESYS PROFINET IO controller. What am I doing...
207
Hi I have a 1511 plc and unidrive M300s communicating over profinet. I can start and stop and change speed ok but I cant workout how to change...
1,142
My current project has a Simatic S7-1200. It involves a robot with two different tools. Each tool has their own Profinet I/O-devices with...
1,968
Hi all, I have a question, I want to change the address of a Profibus slave. My CPU315 is connect via ethernet. Is this possible over...
3,309
We need to exchnage data on our PC application with an S7, fitted with CP343 comms controller. Using Libnodave or AGlink it works, but the speed...
7,888
