How to connect Delta PLC with indusoft v7.5
The Delta website says that PLC controller's communication ports are:
Built-in RS-232, RS-485 & USB ports, compatible with ASCII/RTU protocol. Can be master or slave.
The "ASCII/RTU" term suggests very strongly that they support Modbus RTU protocol.
Indusoft's Modbus RTU protocol driver will easily connect to the controller.
You'll have to figure out exactly what elements of the controller data table are exposed to Modbus, and how they are addressed.
I'm trying to establish communication between an HMI DELTA (DOP-B07E515) and a PLC IDEC (FC6A-D16R1CEE) via the RS-232C/485 module (FC6A-SIF-52)...
576
2,979
Hi guys, I want to connect VFD (vfd110E43a) with PLC (DVP14SS2). 1- How many inputs and outputs needed for the VFD? I want to control it...
3,530
Hello guys, I have a siemens PLC and i want to add a new preocess without touch the Siemens code, so i am going to add Delta PLC, this PLC will...
5,907
I recently purchased a GSM modem model number SGM510 from a local dealer in Mumbai, India and I am trying to connect it to a Delta PLC that I have...
1,689
