Connect HMI DELTA with PLC IDEC via RS 232C/485
gide007
Oct 2023
Thailand
I'm trying to establish communication between an HMI DELTA (DOP-B07E515) and a PLC IDEC (FC6A-D16R1CEE) via the RS-232C/485 module (FC6A-SIF-52). My current settings are as follows:
HMI IP: 192.168.0.2
PLC IP: 192.168.0.95
Baud rate: 115200
Data bits: 7
Parity: Even
Stop bits: 1
For RS-485:
- DP9 pin 1 is connected to module port A1.
- DP9 pin 6 is connected to module port B1.
For RS-232C:
- DP9 pin 2 is connected to module port RD1.
- DP9 pin 3 is connected to module port SD1.
However, I'm encountering errors:
- For RS-485, HMI warning: "COM2 Station 1: Communicate error 3."
- For RS-232C, HMI warning: "COM2 Station 1: Communicate error 2."
Could you please help me identify what I might be missing or if there are alternative options to connect the HMI DELTA (DOP-B07E515) and PLC IDEC (FC6A-D16R1CEE)?
HMI RS 232.jpg HMI RS 485.jpg PLC setting 232.jpg PLC setting 485.jpg PLC.jpg
There is no way you can do Half-Duplex RS485 with that speed. I would try with 9600, E, 7, 1. Also you I advise you to increase communication timeout on HMI side. For RS485, if i remember good, should be connected pins 2, 1 and 7 on MiniDIN connector.
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
341
Hello, I have an old project i did 2 years before, now i need to make a few changes but somehow i cant seem to connect to my hmi. I could access...
956
Sorry for the basic question: At the moment, the PLC [S7-1200] is connected to a laptop (contains TIA Portal) via the ethernet port. When I add...
1,508
So I installed advanced hmi and grabbed an ethernet cable. I have the click C0-12DRE-1-D PLC. I installed the advanced hmi and added the...
2,063
Do I use the ethernet port on the click plc to connect it to my computer. Will advancedhmi work properly? Am I able to start data logging into a...
941
