danw
Where's the excitation current coming from to read the IR drop across the resistance?
As bit bucket says, none of the sensors appear to be Thermocouples. Can you tell us which one you have (model no.)
Yes, but only an RTD card or an RTD transmitter is designed to provide a constant current excitation. DC volt AI cards do not have excitation sources.It should come from the analog input device. Am I right ?
Rashwan Mzhr ...Please use this before I have a stroke
The LM34 device does not require any external calibration or trimming to provide
typical accuracies of ±1/2°F at room temperature and ±1-1⁄2°F over a full −50°F to 300°F temperature range.
Operates From 5 to 30 Volts ........PLC analog range
Less Than 90-μA Current Drain
$2.30 .......cheaper on ebay
http://www.newark.com/texas-instruments/lm34dz-nopb/temperature-sensor-1f-to-92-3/dp/41K4759?mckv=s1pV1qEmc|pcrid|57087234021|plid|&CMP=KNC-GPLA?gross_price=
easy to use:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB4QFjAA&url=http%3A%2F%2Fwww.ti.com%2Flit%2Fds%2Fsymlink%2Flm34.pdf&ei=g6IzVZanCcSzggTTw4CgAg&usg=AFQjCNGV4NvgDOVcwjl9a-zCnWiDRuAnfQ
easy to use:
what is resistance you measure in the connection box?
