Para
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch, establishing a distinct secure network.
On my end, I have the Machine Expert software installed within a local virtual machine (VM) on my laptop, which is connected to our local network.
To enable remote access to the PLC for configuration changes and downloads, we're using SSH tunnelling via Putty software in the VM. Following the guidelines in the M241 manual, I have configured port forwarding within Putty on the VM for the following ports. Additionally, these ports have been forwarded on the router, and corresponding firewall rules have been set up:
*Machine Expert Protocol:
1. UDP Ports: 1740, 1741, 1742, 1743
2. TCP Ports: 1105, 11740 (Fast TCP)
Modbus Protocol:
1. TCP Port: 502
While I am able to successfully connect to the router via Putty and perform Modbus scans on the PLC using localhost (IP: 127.0.0.1, Port: 502) in the VM, I encountered an issue with the Machine Expert software. In the connection settings of Machine Expert, I do not see the controller listed for online access.
I used the Gateway Management Console and added 127.0.0.1:1105, where I observed the state as "Connected as client." However, despite trying various connection modes in the controller communication settings, I was unable to see controller in the list to establish a connection to PLC and go online.
I looked at the Machine Expert help, but unfortunately, I have not found a resolution to this issue.
Can anyone please provide guidance on how we can establish a remote connection to the PLC from Machine Expert software on my VM using SSH tunnelling?
Modbus Protocol:
1. TCP Port: 502
