Sew Movidrive is model MDX61B0150-203-4-OT.
It is connected via Ethernet to STudio5000.
I have a seperation belt that this drive controls and we had a power surge wednesday. I can manually move the belts using the DBG control pad thats is plugged into the drive. But when I use the JOG or/and Auto mode the belts will not move.
I have tried copying parameters from another belt via DBG controller on to this drive and still the same issue.
I am getting the Input from the hmi PB and the Output from plc to the drive.
NOW- I downloaded the MOVITOOLS software from SEW and connected my laptop via ethernet to the drive and once I get movitools open and set up when I SCAN for stuff on the network It never finds the drive.
I have also plugged into the main ethernet hub and it still will not find it.
I have searched and found a few threads about I need a SEW's USB11A cable kit?
If it is controlled via ethernet I should be able to find it when I connect straight it correct?
