How to connect USB device to PLC via RS485
The function is very simple:
- start dispensing
- take dispensed weight
- stop dispensing when set weight is reached
What is important is the accuracy and speed of settling.
This scale is designed to work with a pc and be able to interface with other pc based applications and not directly with a plc. Not to say that you can't make it work somehow but I doubt the effort and cost are worth it.
If you need to interface with a plc it would be better to try and find a scale that will work with the plc directly.
I do a lot of Allen Bradley work and normally choose Hardy for all my scale solutions as they have very tight integration with Allen Bradley plc's.
Not sure what would be the best brand to use with Panasonic as I have never worked with that brand plc before but finding a scale that can work directly with the plc would be the easier road IMHO.
You can use USB to serial convertor of the brand digitus.
This product is especially with Panasonic PLC's compatible.
Digitus Converter USB 2.0 D-Sub 9 Male Black
Hi All, I am using compact Logix 1769-L33ER. I am facing issues while connecting it with the laptop using USB. But when I go with the Ethernet it...
3,807
Hi, i'm using cx programmer 9.5 running on my vmware and trying to connect to my CP1H- XA. I did the required driver installation suggested in the...
2,851
Connecting to a L36ERM Processor, I get this message for my usb driver... "Windows cannot verify the digital signature for the drivers required...
2,092
Dear experts, I can't connect to Siemens s7 200, I have Siemens ppi cable but I don't have serial port on my pc so I used serial to usb converter...
4,546
I want to connect my plc via usb . i attached a picture please see 1st. When i connect 1 into plc and 2 into PC it connected. when i connect 1...
3,251
