How to Convert 24V Step Signal to +/-5
ndzied1
Aug 2002
Chicago, Illinois
2,857
I have a plc w/ a 24VDC pulse output and want to connect it to a stepper drive that takes +/- 5V Step+ and Step- inputs.
In the manual it says I can add some resistors and make it work but I was wondering if there is a converter to do this for me and keep things a little cleaner.
Thanks,
Use a resistor and a zener diode. That is probably your easiest solution. A more complicated and expensive one is to use an Opto-22 type isolator module, or just add a 5VDC PLC output module.
In most cases I found it easier to use the stepping motor amplifier/driver to simplify issues. It costs more but offers better benefits in the long run.
I had to take care of a flexo printing press that used 56 stepper motors so every time I got a chance I played with them and a plc. Directly driving one with a plc can get complicated, especially a 5 phase with encoder.
Hi, Has any body got practical knowledge of using a 12VDC to 24VDC convertor? A quick Google search produces 100s of options at a variety of...
2,303
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
92
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
322
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,406
Hello, could someone kindly convert the attached RSP files that are currently used for SLC 5 PLC into PDF please
537
