How To Create a Pop Up Display Triggered by Change of State in FactoryTalk Studio ME
JKanyce
Oct 2021
Atlanta, GA
I need to add a pop-up display to an existing PanelView Plus program. However, I'm not understanding what I need to do with the Global Connections and Macros.
Say I have a tag named 'var.' If var changes state from 0 to 1, I want a "pop-up" display to appear. I want this pop-up display to appear "on top" of any of the other display screens whenever the state of var changes from 0 to 1 regardless of what screen is currently displayed on the HMI.
It seems like it should be fairly simple, yet I cannot figure it out. Any help would be greatly appreciated.
*This is for FactoryTalk View Studio - View Machine Edition
Macros are not necessary, just global connections.
Create your display, setting it as 'on top' and giving it a unique display number.
In Global Connections set an integer tag (let's call it 'HMIDisplayTag') for 'Remote Display Number'. In your PLC program, when your 'var' tag changes from 0 to 1 then move the value you set as the display number into HMIDisplayTag. This will trigger the HMI to open the display with that number.
Make sure to move a zero back into HMIDisplayTag, as having anything other than zero in it prevents the operator from changing screens at the HMI.
Hello everyone. I have HMI(got 15**) develop by GTD3. I want to create popup windows. I can do it? Thank you.
1,884
I am trying to create a pop up button on a Proface HMI using GP-ProX. I want the button to pop up when a bit is set and then be able to push the...
3,670
Hello friends. I am using the touching panel AGP2400-S1-D24 and communicating with PLC Allen-Bradlley 1769-L35E. I would need just to know how to...
4,148
I've got to add a new screen to an existing WinCC project. The screens drawn, it's variables are now linked to the Step7 variables thanks to a bit...
18
22,109
Hi all, recently, I deployed Intouch SCADA to the 7 clients PC, but one PC got pending to update the objects and unable to successful. There is...
31
