How to define a Push-button in RSview32?
Shawn Yi
Guest
S
Hi all Masters,
Right now I'm learning RSview 32. I can make a tag for a bit, I drop a push-button from library. I can use toggle command to make it on or off, but you know, when we turn on or off a motor, normally we can't toggle it, we need a push-button for on, another for off. Could you please tell me how to make the bit action momentarily?
Thanks.
Shawn
The logic in the PLC should be a classic start/stop control circuit, ie: N.O. start PB, N.C. stop PB and N.O. latching contact. The pushbuttons in View should operate just as a mechanical switch would.
When you double click on a button for editing the button configuration screen should appear and from there you can select momentary.
Also, not sure if I understand you correctly but you can make your own push buttons using the drawing toolbox (instead of going to the library all the time). Go to View up in the main toolbar and check Drawing Toolbox. On mine, it is the last one to the right. It is a rectangle with a finger.
Bob O
hello dear forum, About DELTA DIAView SCADA I defined a variable in Timescript VBscript I want access this variable from within a window For...
587
Hello PLCS.Net! I have the EDS Hardware Installation Tool installed on my PC. When I try to install a file, It says it's successful, the...
2,038
Hi all, I want access a Mitsubishi PLC Q series to SMC. I am using Archestra DASMTEthernet as my server in SMC to connect with PLC. After I...
1,420
Hi, I was wondering if anybody can help me with this issue. I have *.cab backup created from a lower version (Dev Studio 2012R2) and I loaded it...
5,363
Hi Guys, I searched throughout the forums but didnt find any information on this topic. I currently have an application that relies on macros...
1,616
