How to enable source protection in several versions of RSLogix 5000?
asteroide
Jul 2010
der
158
Hello Friends
I have a installation with v16, v17, v18, v19, v20. When I tried to open a v20 file, the enable source protection was not enabled. So I run the enable source protection from the installation folder, and I can open the v20 file and the menu enable source perotecction enable.
But I tried to open a file v17 and the enable source protection was disabled.
If I open the v20 the enable source protection works, but not with v17.
How can I fix that?
Thanks in advance
It doesn't look like you have a project open in the image you posted. The controller box is telling you that there is no controller. I am pretty sure that source protection is on a program by program basis. If you don't have a project open, there is nothing to protect. It isn't enough to open RSLogix V17, you have to open a project made in V17.
Hello I have In touch 10.1 I tried to enter the WindowMaker to make some adjustments I am using a dongol for the license . I can access the...
88
I'm using one TON (called SystemTimer) throughout a program that I change the .PRE given different conditions. I'm porting an IDEC ladder over to...
317
Hi there, Maybe I am overthinking this issue, but here is what I have going on. I have a program running for a water valve on a DI system. We...
449
I have a FSC instruction that won't enable. I check tags and data type and can't find the problem. I'm trying to pull index numbers for data...
731
I have to carry out a programming where I have some valves and it has to meet these requirements: If the OPEN button is energized and the RETRO...
1,513
