How to fetch live data from s7-300 PLC in a PC
Feb 2011
karachi
I 'm newcomer in PLCs. I want to fetch live data from a s7-300 PLC in a windows based PC. Please suggest me what is the least cost way of doing this.
I have come to known that it is done using OPC server. OPC servers seems to be costly,can i do it without OPC server.
Someone told that it is possible using winc software,is it true?
OPC servers are not expensive. On the contrary.
Since you seem to be cost-conscious, and if this is a one-off project, I recommend that you get a shrink-wrapped datalogger for OPC. Google for "Datalog OPC Client".
A very low cost datalogger for S7-300 is Deltalogics Easylog. It logs to simple CSV files, and works without having to purchase an OPC server.
I 'm newcomer in PLCs. I want to fetch live data from a s7-300 PLC in a windows based PC. Please suggest me what is the least cost way of doing...
2,599
Hello All, is there any way to fetch remote controllers Mode Run/Remote Prog/Faulted etc. ( AB L8 Series) using CIP message, if yes please share...
826
Hello every body I linked Proface HMI "GP2500-TC41-24V" to S7-315 2PN/DP. As attached I have to enter PN port fetch/write port number. How...
1,590
Hi guys, I'm wanting to set up a fetch / write on a s5 and s7. But i'm struggling to work out which i should use, if not both? I want to share...
1,821
hi.... I have a dual redundancy control logix plc on controlnet. There is also a panelview 1500 on the same network. I want to fetch the panelview...
2,959
