How to find the Calculated Values in Wonderware System Platform 2014 R2
ar879
Jun 2017
Toronton
Hi guys,
This is my first thread in this forum. I'm wondering if some of you here are experts in using Wonderware System Platform 2014 R2.
I'm working on an existing system for a client; The system displays data from power sites such as; Real Power, Reactive Power, Power Factor, etc. The Client said that the data displayed on the HMI is not accurate.
I tried checking the embedded objects in both InTouch and ArchestrA to fix the scripts which are used to display the required data but couldn't find any!
When I checked the attributes of the objects which are used to display the data in ArchestrA, I could see that they are "Calculated", but where are they calculated?? Where could the scripts which include the math used to calculate the values for each power data possibly be?? Could someone help please!
Thanks!
There are many options to realize such a calculation:
- Cyclic window script
- Script triggered variable change, like $second or on change from the external variable
- Calculation done inside a window on any animation
If you've got the name of the variable, I would first check if it's an internal or external tag. Then use the cross reference to see where the variable is used. Check all options in cross reference search.
I vaguely recall seeing this attribute, but can't find it just yet.
Can you post a screen shot of where you found that property please?
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
119
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
142
I have tested every screen and no single screen individually has this fault pop up, but when I compile and send to the PanelView it comes up. If I...
190
Hi, One of my customers has an old fabric tensile testing machine. The IC # AD7501KN of its controller has malfunctioned. This IC is related to...
86
Hello everyone, I am a student and would like to take the next step and learn FactoryTalk (Batch preferably) and how to create HMIs etc. Would...
501
