How to import tags to FT View Studio
MattMatt9
Jun 2020
Canada
119
So I have copied the MER file from a panelview and converted to MED file. How to get updated tags to use in displays. I know i have to do something through FactoryTalk Linx -> Communication Setup. But I see "device shortcuts" and "design (local)" and "runtime (target)". And offline tag file and just dont really know the process. Plus isnt there an online folder too?
From the sounds of it you are wanting to choose a new path to the PLC program. Is that correct? If so there should already be a name in the "device shortcut" window. All you have to do is click that name and navigate to the PLC in the "design (local)" window, then hit "apply" above the "device shortcut" window and "ok" near the bottom of the screen. You can then test a screen or two to make sure the path works.
Once you're ready to put it back you'll have to click the "copy from design to runtime" button and then use the "create runtime application" to convert it back to a .mer file.
Try right-clicking the ethernet driver and then start browsing. If the PLC still doesn't show up then you may need to add a new device under the ethernet driver with the IP address.
2,909
Dear All, I am trying to import tags and alarms tags in FT view SE 5.0 by using import & export tool... but its giving me message that i need...
8,771
I tried importing some timer tags into factory talk but only 4 or 5 of them came up. I'm trying to use the tag name for the timer to allow the...
19,444
I am manually (by hand) converting an application from RSViEW 32 to RSView studio Me. I have 700 alarm tags to covert. Does anyone know of a...
3,756
I can't find out how to import the tags i created in rslogix 5000 (controllogix 5555 processor) into the Panelview plus 1000 operator panel. Does...
13,409
