How to online/run ML1200, its CH0 is config as "Modbus RTU Slave"
bundhit
Sep 2003
Bangkok
39
I use RSLogix500 downloas backup program to ML1200 via DF1 driver. In the backup program, the channel was configured as "Modbus RTU Slave" So, when I finished downloading, I could not online or run the cpu. Any comments, please share.
I dont use the ML1200 but from the Rockwell manual I have, it reads
The 1762-LxxxxxR ML1200 has 2 comms ports one on front one on side
There is also a Comms pushbutton that allows access to CH 0 to be toggled
Dear Everyone I work with PLC GE-Fanuc. But I don't know that "PLC GE-Fanuc (Series 90-30 and VersaMax) can Online Edit Programming while...
3,135
Good Morning , I need to make a online change to a SLC 500 5/05 . Is it safe to turn the key from Run to Remote with causing the processor...
1,893
Hello Experts, Will there be any issue if i add a routine Online in Run Mode?? Will it require a download? I don't have a live PLC for simulation...
3,561
155
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
89
