SLC 500 5/05 -when doing a online edit can you safely turn switch from Run to Remote?
Rob S.
Sep 2008
Maryland
739
Good Morning ,
I need to make a online change to a SLC 500 5/05 . Is it safe to turn the key from Run to Remote with causing the processor to fault ?
Thanks so much in advance ,
I have never had a issue, you should be able to flip the key than start editing... also the only why it will fault is if you have a problem with your program and if you have not changed anything your just changing the mode of the PLC
yeah. Switching from Run to Remote is easy. It will allow you do perform online edits. Be careful not to accidentally switch the key to program mode... that tends to cause issues hahaha...
One thing to keep in mind... if they've added an eeprom, it may be set to auto-load the progam when power is cycled. If that's the case, you'll need to find a time to flash it, and/or be prepared to possibly lose the edits the next time your plant has a brownout
Good Afternoon, I'm trying to do online edits on a SLC 500 5/05 . After I put my instruction in , I keep getting " Test Edits Failed " ...
3,748
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
961
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
768
In a slc 500 plc I am trying to move data with out using a lot of moves. I want to move data from n7:1 to n7:2 and data that was in n7:2 to n7:3...
1,356
Customer has a circa 2004 SLC-500 PLC. Fieldbus is a 1747-SDN DeviceNet scanner. Customer has SLC-500 file (.rss) with no comments. Has no *.dnt...
558
